Advice on Pajero bumper fabrication
- This topic has 24 replies, 8 voices, and was last updated 9 years, 3 months ago by
Fon Genrih.
Hi Neasboy. I have also a Pajero and it had the same original metal skid plate which is quite strong but may be not enough as I managed to destroyed it. I went to Best Line garage 2 weeks ago and they made for me anotherone that looks stronger. I will be on the drive Friday afternoon if you want to see it. Pierre.
quote Pierre2016:Hi Neasboy. I have also a Pajero and it had the same original metal skid plate which is quite strong but may be not enough as I managed to destroyed it. I went to Best Line garage 2 weeks ago and they made for me anotherone that looks stronger. I will be on the drive Friday afternoon if you want to see it. Pierre.Thanks Pierre . I have the LWB 3.8L
IT will be great to see the skidplate and check it’s construction. Guess I’ve not put the original through enough to break it yet :-ss
To close out the thread, I went for the rear and front skid plates, along with a trim of the front bumper that was damaged. Photos attached, feel free to climb under the car at this Fridays drive and have a look. Also got a ABS isolation switch installed for 150 dirhams. saves further crawling under the car to disable it or pulling fuses.
@ extensive7 Car is a 5 door, 3.5 litre.
Took Alex’s advice, got he work done at 5 star. Looking forward to hitting the sand shortly!
JasonJanuary 11, 2017 at 6:27 am #37802quote jasonm:To close out the thread, I went for the rear and front skid plates, along with a trim of the front bumper that was damaged. Photos attached, feel free to climb under the car at this Fridays drive and have a look. Also got a ABS isolation switch installed for 150 dirhams. saves further crawling under the car to disable it or pulling fuses.@ extensive7 Car is a 5 door, 3.5 litre.
JasonGood job man :yesss: How much did they charge u and is that steel or aluminium? what is the thickness?
~ 1200 Dirhams for the front and 800 for the back. Seems to be the going price with the reputable 4×4 shops.
Both aluminum, rear 3mm plates with rubber coating. Front 8mm with Nylon bushings/spacers to help with vibration.
As I was pulling out, another car was pulling in with rear bumper damage to get the same work.
January 11, 2017 at 8:46 am #37804quote jasonm:~ 1200 Dirhams for the front and 800 for the back. Seems to be the going price with the reputable 4×4 shops.Both aluminum, rear 3mm plates with rubber coating. Front 8mm with Nylon bushings/spacers to help with vibration.
very nice! its a good armor at the front with 8 mm aluminium! its important that u protected engine bay and first weak thing is actuator, at the back 3 mm more than enough. for me it was simply plastic cover which didn’t give rear bumper to be a shovel on tight places!
January 11, 2017 at 9:22 am #37806quote Neasboy:That front skid looks awesome ! like a Friday 13th halloween mask mate or something from Mad Max movieFriday 13 drive is coming btw 😉 :))
