Newbie, FEwbie and Intermediate Drive on 30th May 2014
- This topic has 25 replies, 14 voices, and was last updated 11 years, 10 months ago by
Elie.
I will rename yesterday’s drive as “Camel-gate” (which will be explained later). The newbie convoy was led by Humayan – who decided to steepen the learning curve for the first and few timers alike. By his own admission the route we took was fairly technical and it definitely lived up to it.
Sweep Matthews was kept busy from the off. The first recovery required pulling me off the crest on which I had decided to turn my truck into a giant see-saw (chassis down and minimal contact with front or rear tires). Oops. Once recovered we met with the rest of the convoy that was practicing side sloping. From there Humayan navigated us through/around/over some tight/steep bowls/crests. On the way we had a few stucks, some of which were pulled out of, some of which Matthews took over the car and self recovered. At one point the lead himself needed a helping pull from Matthews, which showed that getting stuck was all part of the sport regardless of experience. All good opportunities to learn from.
As it was getting later we decided to make our way out of the sand, and this is where context will be given to the first sentence. On the way back a SWB patrol came up along side the convoy and told us that we had to exit via a different route. I assume that this was because we were driving into a roaming herd (?) of camels. We changed our direction accordingly…but before long the white patrol was on us again pointing us in a different direction. After a little conversation it appeared that the patrol was just going to escort us to a track and back to our starting point at the mosque. There ended the drive.
Though it seemed like we didn’t cover a huge amount of ground (although we might have) there was a lot to be learnt on the path that Humayan drove us. A good experience all around. Thank you.
Majid
Our group is led by Fida and sweep by Aemi was a good drive.
Got stocked 2 times but was able to do self recovery (thanks) to Aemi for the guidance.There was this area where (almost everyone got stock) – with the temperature heating up, wind blowing and sands are flying, it was a different experience (for me)
Then was the fast drive in some point as we chase down the sunset.
Again, thanks guys for the company and the learning experience. :thanks:
quote MJJ:I will rename yesterday’s drive as “Camel-gate” (which will be explained later). The newbie convoy was led by Humayan – who decided to steepen the learning curve for the first and few timers alike. By his own admission the route we took was fairly technical and it definitely lived up to it.Sweep Matthews was kept busy from the off. The first recovery required pulling me off the crest on which I had decided to turn my truck into a giant see-saw (chassis down and minimal contact with front or rear tires). Oops. Once recovered we met with the rest of the convoy that was practicing side sloping. From there Humayan navigated us through/around/over some tight/steep bowls/crests. On the way we had a few stucks, some of which were pulled out of, some of which Matthews took over the car and self recovered. At one point the lead himself needed a helping pull from Matthews, which showed that getting stuck was all part of the sport regardless of experience. All good opportunities to learn from.
Majid
SWB Nissan patrol was CID (Security Guy) for protection of Wild Life camels and gazelles. We were lucky that this guy spotted us only at 5.10pm else our whole drive would have spoiled.
Anyhow nice area to test the skills by all levels..
quote khshareef:quote MJJ:I will rename yesterday’s drive as “Camel-gate” (which will be explained later). The newbie convoy was led by Humayan – who decided to steepen the learning curve for the first and few timers alike. By his own admission the route we took was fairly technical and it definitely lived up to it.Sweep Matthews was kept busy from the off. The first recovery required pulling me off the crest on which I had decided to turn my truck into a giant see-saw (chassis down and minimal contact with front or rear tires). Oops. Once recovered we met with the rest of the convoy that was practicing side sloping. From there Humayan navigated us through/around/over some tight/steep bowls/crests. On the way we had a few stucks, some of which were pulled out of, some of which Matthews took over the car and self recovered. At one point the lead himself needed a helping pull from Matthews, which showed that getting stuck was all part of the sport regardless of experience. All good opportunities to learn from.
Majid
Dear Majid,
i must say.. a well described brief on the whole trip with each detail .. cheers !! 😉
well i hope the CID thing does not happen with us again.. and i am sure there are loads of other tracks and dunes waiting for us. :drive:Hey Humayun.. it was indeed an amazing drive and a great learning experience. Not really a rocket science.. but your experience was of tremendous help 😀
Waiting for next drive already.. i hope its soon !Cheers guyz..
Happy Offroading !!Nishant
June 1, 2014 at 11:07 am #30316Al Lisaily and Al Faq’aa are designated conservation areas with a number of projects planned in the not too distant future.
There will progressively be more restrictions both for access and to drive around in the designated areas.quote Ahmad Pervez:Al Lisaily and Al Faq’aa are designated conservation areas with a number of projects planned in the not too distant future.
There will progressively be more restrictions both for access and to drive around in the designated areas.Looks like in near future only sweihan and Tall Moreeb will be the option…
Our seven cars convoy successfully tackled some not so easy crests and dune crossings all throughout an enjoyable medium paced drive, and a perfectly timed ending. Thanks are in order to both: Feroz for leading us thru a very tricky maize of soft sand and to Rakesh for his tireless efforts every time we had a stuck or a pop-out. It also goes without saying that it is always nice to meet new people who share the same passion for the desert. You guys know who you are, and I look forward to driving with you again and in the near future.
