Offroad Walkie Talkie FAQ
- This topic has 82 replies, 1 voice, and was last updated 1 year, 2 months ago by
Sandboxman1972.
quote Waleed4x4:Hi guys. I have crony888. Does anyone have this model ? Can you help me on finding the user manual or guide me the steps to configure the frequency?
Thanks
Hi @Waleed4x4, I am using Crony Radio. Well dont remember which model is it, I’ll check once I reach home. But Im sure working will almost be same, so I will post how to program it or will help u tomorrow.
quote Waleed4x4:Hi guys. I have crony888. Does anyone have this model ? Can you help me on finding the user manual or guide me the steps to configure the frequency?Thanks
Hello @Waleed4x4
Found this online, give it a try:
For those who have the Crony CY – 888 two way radio….please see below channel programming process. If anyone has found a better way of doing it, please let us know as well.Crony CY 888 channel programming
Enter the frequency for channel 1 physically as 464.562. The 5 will come automatically per the program inside.
Press Funtion “F” and press “#” for storing and then select channel “01” using “A” for up and “B” for down. and then press “D” for storing launch frequency (speak).
Then press F and press # and then press “C” for storing receive frequency (hear). The channels for speak and hear are they same for off-road purpose. Channel 1 is now set.
To confirm Press F and press 1. You will see CH – 01 on the screen.
Press F and 1 again. You will now see the frequency 462.562 5 and 01 on the screen.
For Channel 2 and subsequent channels
Now press F. You will see the frequency displayed as 462.562 5. Press A and keep pressing till you come to 462.587 5.
Press F and you will see channel 01 on the top which is the earlier stored channel. Press A to select channel 2 and press F # D for storing this frequency as launch frequency and repeat above for receive frequency. In this way you can store all the channels upto 22. ”
Check if it helps.
Cheers
Samquote samonajj:quote Waleed4x4:Hi guys. I have crony888. Does anyone have this model ? Can you help me on finding the user manual or guide me the steps to configure the frequency?Thanks
Hello @Waleed4x4
Check if it helps.
Cheers
Sam@samonajj these steps are same as I did for my Crony radio ๐ . Just like to add 1 more step before starting this is to change the frequency step size from 25Hz to 12.5Hz. If I’m not wrong it can be done by pressing F then no. 4 this will show the current frequency step size. Then press no. 4 again 1-2 times to set 12.5 Hz. Then follow the steps to save the channels.
Cheers.Crony CY 888 channel programming guide.
Someone asked for this last weekend so here it is.
Enter the frequency for channel 1 physically as 462.562 The 5 will come automatically per the program inside.
Then press Funtion “F” and press “#” for storing and then select channel “01” using “A” for up and “B” for down. and then press “D” for storing launch frequency (speak).
Repeat For Channel 2 and subsequent channels up to 14.
1—————- 462.5625
2—————- 462.5875
3—————- 462.6125
4—————- 462.6375
5—————- 462.6625
6—————- 462.6875
7—————- 462.7125
8—————- 467.5625
9—————- 467.5875
10————— 467.6125
11————— 467.6375
12————— 467.6625
13————— 467.6875
14————— 467.7125hello guys
am new member here, and this topic made me want to be a member, i do use the mobile ( Runbo H1A UHF/VHF+4.5” QHD ) it has the PPT and i can set 16 different frequency in 16 channel. yesterday in china market i was trying to connect it to other walkie talkie devices and it was successfully connected to ( PROLAB PRY-RAD52CM1 ), i just programmed one of the frequencies posted and i hope it works with me on my first trip with you guys looking forward.
:thanks:
AnonymousSeptember 18, 2016 at 2:48 am #36503Dear Abdulla, welcome to DO, looking forward to meet you on the sand.
Please make sure to program all above listed frequencies into your radio as the marshals can decide to use any frequency on the drives, hence it is important to have stored them all.
Cheers,dear all
i recently bought icom ic-2720 its a fixed mobile walkie talkie in the car, it reads both VHF/UHF. it works perfect on the VHF channels in receiving and transferring but when it comes to UHF i can only receive very clear but cannot send. do anyone here have the experience that might help me or know somewhere i can visit to check.
thanks all
quote Ahhelmi:Hi guys i have a problem . I have 2 devices both recive but dont send
Iv programed the channels
Iv extended the frequency range
Dont know whT i should do
Any help ?Hi @Ahhelmi,
Are you sure you set both sending and receiving frequencies? Also which brand of radio do you have? If its a Crony check out this post by SamA.
http://www.dubaioffroadlive.local/forums/viewtopic.php?t=1453&start=40#p40806
Hope it helps
quote Ahhelmi:Hello Sami,
Thanks for the reply i have a motorola it so the above doesnt apply.
But what u mean set sending and reciving frequencies?
You mean after going to self stiing then entering the frquency number 2 times when programing channel 1 for example ?ya something like that. Its slightly different for Motorola. maybe this video will help.
http://www.dubaioffroadlive.local/forums/viewtopic.php?f=16&t=3190&p=39851#p39851
See this link: http://www.dubaioffroadlive.local/forums/viewtopic.php?f=16&t=1454&start=30#p42899
I was there in January 2017 and bought the Motorola MT -777. Got it for 175 had to pay 10 DH extra for the car charger. He did the programming with is computer and 5 minutes later I had the radio.
If you have problems with programming go to this shop he will do it.
:yesss: ๐
